Using Siebel Tools > Managing Repositories >
Reviewing Information About the Current Repository
The About SRF option on the Siebel Tools Help menu provides version, compilation, and path information about the current repository.
To review information about the current repository
  • In Siebel Tools, choose Help > About SRF.
    The About Repository File window appears and displays the following information.
Field/Button
Description
Internal version
Version number maintained internally at Oracle that changes only when the internal format of the SRF file changes, such as at the time of a major release. It has no significance for customer developers.
User version
Reserved for use by Oracle's Siebel Anywhere, which maintains this number when kits are created that upgrade the SRF file. The value is read when a version check occurs.
Full compile option button
Select to display information about the most recent full compilation in the Compile Information fields.
Last incremental compile option button
Select to display information about the most recent incremental compilation. If there have been no incremental compilations since the last full compilation, this option button is unavailable.
When
Date of the last compilation—incremental or full, as specified in the option buttons.
Machine name
Name of the client computer on which the SRF file was compiled.
Language
Language code of the language specified for user interface translation.
User name
User name (that is, the Microsoft Windows logon name) of the user who compiled the repository.
Repository
Repository name of the repository that was current when the compilation was run, generally Siebel repository.
Tools version
The version number and build number of the Siebel Tools software used to compile the repository. This is useful information for Siebel Technical Services if they are helping you in resolving a problem with your configuration.
Schema version
Database schema version of the database from which the repository was compiled.
File name
Name and path of the SRF file being used internally to define the Siebel Tools application, located in SIEBEL_TOOLS_ROOT\OBJECTS.
Using Siebel Tools
