Using Siebel Tools > Managing Repositories > Deleting RepositoriesThe delete process remove all records associated with the repository. Be sure to back up the repository before you delete it. CAUTION: Deleting a repository takes a long time and requires resources such as rollback segment, cursors, tablespace, and so on. Consult your DBA before deleting a repository. |
Using Siebel Tools |
