Using Siebel Tools > Siebel Script Editors > Using the Siebel Debugger > Checking SyntaxThe debugger includes a syntax checker to make sure that your script compiles properly. To check the syntax of your script
CAUTION: The Check Syntax function checks only for syntax errors and errors that stem from failure to properly initialize objects or variables. It does not check other types of errors, and cannot trap errors in logic that may cause run-time errors. At this point, your script should run. Test it to see if it gives you the desired results. The following sections describe debugging tools to help you accomplish that end. CAUTION: The Check Syntax command checks only the script in the active object definition. If there are errors in other scripts, you are not able to compile the SRF file. |
| Using Siebel Tools |
