Using Siebel Tools > Siebel Script Editors >
Setting Script Assist Preferences
You set preferences for Script Assist in the Development Tools Options window.
To set Script Assist preferences
  1. From the Siebel Tools View menu, select Options.
    The Development Tools Options window appears.
  2. Click the Scripting tab.
    The following table describes the different fields in the Script Assist Window.
    Field
    Available Options
    Enable Method Listing
    When checked, a list of declared methods and properties will appear in the Script Assist window for each selected object.
    NOTE:  For Script Assist features to be fully enabled, you must check this box.
    Enable Auto Complete
    When checked, Auto Complete is enabled.
    Auto Indent
    When checked, each succeeding line is indented to the position set by the current line.
    Tab Width
    Set the tab width, in increments of spaces. The default setting is 4.
Using Siebel Tools
