Using Siebel Tools > Working with Objects >
Viewing Object Relationships
You can use the Siebel Tools Visualization views to see how objects relate to one another. To invoke the Visualization views using the View menu
- Choose View > Visualize > View Details, View Relationships, View Descendents, or View Web Hierarchy.
To invoke the Visualization views from the Object List Editor
The Visualization views are described in Table 34.
Table 34. Description of Visualization Views
Details |
Generates and displays a Details visualization view for the currently selected business component or business object. The diagram displays how the business component maps to underlying tables (directly or through joins) and maps to other business components (through links). |
Relationships |
Generates and displays a Relationships visualization view for the currently selected business component or table. For business components, the diagram displays how the business component links to other business components using multi-value link objects. For tables, the diagram displays how the table joins to other tables by way of join objects. |
Descendents |
Shows all objects which have the current object marked as their Upgrade Ancestor. |
Web Hierarchy |
Generates and displays a Web Hierarchy visualization view for the currently selected applet, application, business component, screen, or view. The diagram displays the parent-child relationships between the selected object and its parent and child objects, as well as the parents of the parent objects and children of the child objects, up and down the hierarchy. |
