Using Siebel Tools > Working with Projects >
Renaming Projects
You can rename projects that you have created. However, you must rename the projects on the server, not on the local database. You cannot change the name of a top-level object that has been checked out.
CAUTION:  Do not change the name of projects to which Siebel objects are associated.
To rename a project on the server
  1. Make sure developers have checked in all checked-out projects.
  2. Use Siebel Tools to log into the server database.
  3. Choose File > Open Repository, and then select the repository you want to modify.
  4. Navigate to the project you want to modify.
  5. Lock the project, and then change the Name property.
  6. Have developers perform a Get of all projects on the server repository.
  7. Have developers perform a full compilation the next time they compile.
Using Siebel Tools
