Using Siebel Tools > Working with Projects > Preventing Object Check In and Check OutYou can prevent developers from checking out and checking in projects by locking the project directly on the server repository. CAUTION: Modifying objects directly on the server repository for purposes other than preventing check in and check out is not recommended.
Using Siebel Tools |
