Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the String Conversion Utility > Parameters for Running Consoleapp.exe to Convert StringsThe parameters for running Consoleapp.exe to convert existing locale strings to symbolic strings are shown in Table 40. The format is: Consoleapp.exe < Table 40 lists the parameters and the descriptions.
Using Siebel Tools |
