Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the String Consolidation UtilityAfter locale strings have been converted to symbolic strings, you can use the consolidation utility to find duplicate symbolic strings and merge them and their references into a single symbolic string. The consolidation process is implemented as a business service. You run it using the Consoleapp.exe utility, located in the SIEBEL_TOOLS_ROOT\BIN directory of your Siebel Tools installation directory. Topics in This Section |
Using Siebel Tools |
