Using Siebel Tools > Working with Strings and Other Locale-Specific Data >
Entering String Overrides
Each object property that stores a translatable text string, such as the Title property of an applet, has a corresponding String Override field, for example Title - String Override. In cases where the symbolic string for a given word or phrase does not meet your linguistic requirements, you can override it by entering a value in the override field. Values entered into override fields are stored as child locale objects of the top-level object type (for example applet) for the current Tools language mode. Values stored in string override fields are language-specific and do not affect other references to the symbolic strings.
NOTE:  To be able to enter string overrides, the EnableToolsConstrain parameter in the tools.cfg file must be set to FALSE.
To enter a string override
  1. Navigate to the object and property for which you want to enter a translatable text string.
  2. In the string override field, enter the string.
    The value entered in the string override property is stored as a child locale record and the value automatically populates the translatable text string field, such as the Title property for an applet.
Related Topics
Setting the Constrain Mode for Working with Symbolic Strings
Using Siebel Tools
