Siebel VB Language Reference > VB Language Overview > Object Handling in VB >
Using Methods and Properties to Act on Objects
To access an object, property or method, use this syntax:
appvariable.object.property
appvariable.object.method
For example, me.GetPickListBusComp("Sales Stage") is a value returned by the GetPickListBusComp method of the BusComp object for the Siebel application, which is assigned to the object variable oBC.
