Siebel eSales Administration Guide > Integrating Siebel eSales with Third-Party Payment Applications >
Installing CyberSource Software
The steps to take for installing CyberSource are as follows:
  1. Obtain a merchant ID.
  2. Download the compressed file for the CyberSource Developer Kit (CDK) for your platform.
  3. Install the CDK on the Siebel Server; set the system variables for the CDK and libraries.
For instructions on installing CyberSource applications, see the CyberSource documentation. For information on which versions of CyberSource software are supported by Siebel applications, see System Requirements and Supported Platforms on Siebel SupportWeb. It is recommended that you download and use the latest version of CyberSource software from http://www.cybersource.com.
