Siebel Business Process Framework: Workflow Guide > About Siebel Tools and Process Properties > About Process Properties >
Passing a Process Property to an Error Workflow Process
You can pass more than just a system-defined process property to an error workflow process:
- To pass the original process instance to a user-defined process property to the error process, you must explicitly recreate those user-defined process properties in your error process, giving them the same name and data type.
- To pass a property set from the original process to the error process, you must create a common user-defined hierarchy process property in the original workflow process and in the error process, then use this common hierarchy property to pass the property set.
- To get the name of the original workflow process, you must create a common user-defined process property in the original workflow process and in the error process, then pass the original process name through this common user-defined process property.
To create a process property that passes data to an error workflow process
- Perform the procedure described in Defining an Error Exception.
- Click the Stop step, then define an input argument in the MVPW using values described in the following table:
Name |
%1 |
Type |
Literal |
Value |
Error Message (or a valid string.) |
- In the Workflow Processes OBLE, define a new workflow process that references the error workflow process.
