Implementing Siebel Business Applications on DB2 UDB for z/OS > Maintenance Considerations for z/OS > Dynamic SQL in the Siebel Application > About SQL Tracing on the DB2 HostDetermine the tracing to set on the DB2 host in conjunction with the DBA. Refer to the documentation for the DB2 performance monitoring tool you use to determine how to enable the tracing. |
Implementing Siebel Business Applications on DB2 UDB for z/OS | Copyright © 2008, Oracle. All rights reserved. | |
