Implementing Siebel Business Applications on DB2 UDB for z/OS > Maintenance Considerations for z/OS > Tracing the Source of a QueryAdministrators can identify the terminals from which queries are generated using the Session ID. The session ID is composed of three parts: ClientIP_ClientProcessID_SerialNumber. The following is an example of a session ID: Eventually, the Object Manager and the DB2 host share the same string which can be used to identify the current connection. After the session ID is displayed at the Server Manager, you can also check it on the database side. To verify session ID on the DB2 host
Implementing Siebel Business Applications on DB2 UDB for z/OS | Copyright © 2008, Oracle. All rights reserved. | |
