Siebel Product Administration Guide > Siebel Configurator Rule Assembly Language > About Operators in Rule Assembly Language >
Attribute Operators in Rule Assembly Language
Rule Assembly Language includes special operators for doing comparisons and particular math operations on attribute values. These operators extract information about the attributes of all the products that have been selected in a relationship. For example, you can determine the number of relationship items that have been selected that have an attribute value greater than a specified amount.
Attribute Comparison Operators
These operators return the number of relationship items that have been selected for which the comparison is true. For example, you can use numAttr> to find out how many items with Length greater than 5 feet in a relationship have been selected.
The operators count all the items selected from the relationship, not the number of different items. In the preceding example, if the user selects two of the same item and enters a length greater than 5 feet, the numAttr> operator will return 2.
The operators take two arguments, A and B. Argument A is the full path from the root of the product to the attribute. Argument B is the comparison value. This value can be of type Integer, Number, Date, or Time. Type DateTime is not supported. Argument B can also be a sub-expression that resolves to one of these data types.
In addition, for the numAttr== and numAttr!= operators, argument B can be a text string.
Use attribute comparison operators to create subexpressions that form conditions. Attribute comparison operators are shown in Table 34.
Table 34. Attribute Comparison Operators
Operator
Syntax
Properties
Greater than
numAttr>(A, B)
Returns the number of items in the relationship for which the value of attribute A is greater than B.
Not less than
numAttr>=(A, B)
Returns the number of items in the relationship for which the value of attribute A is greater than or equal to B.
Equals
numAttr==(A, B)
Returns the number of items in the relationship for which the value of attribute A is equal to B.
Not equal to
numAttr!=(A, B)
Returns the number of items in the relationship for which the value of attribute A is not equal to B.
Not greater than
numAttr<=(A, B)
Returns the number of items in the relationship for which the value of attribute A is less than or equal to B.
Less than
numAttr<(A, B)
You can use the numAttr operators to create "any/all" conditions in constraints involving attributes:
  • You create the condition "any instance of products in R has attribute A=X" as follows:
    >=(numAttr==(@.[R].[A], X), 1)
  • You create the condition "all instances of products in R have attribute A=X" as follows:
    ==(numAttr==(@.[R].[A], X), @.[R])
For example, you want to write the constraint, when all the instances of products in P have attribute A=X then exclude any instance of products in Q that have attribute B =Y. You would write this constraint as follows:
excl(==(numAttr==(@.[P].[A], X), @[P]),
>=(numAttr(==(@.[Q].[B], Y), 1)))
Attribute Arithmetic Operators
The arithmetic operators allow you to determine the maximum and minimum value of an attribute for items that have been selected in a relationship. You can also sum the values of the attributes.
The operators take one argument, which is the path to the attribute. Attributes can be of type Number, Integer, Date, or Time. DateTime and Text are not supported. If the type is Date or Time, minAttr returns the time or date closest to the present. The maxAttr operator, returns the time or date furthest from the present.
Use attribute arithmetic operators to create subexpressions that form conditions. Attribute arithmetic operators are shown in Table 35.
Table 35. Attribute Arithmetic Operators
Operator
Syntax
Properties
Minimum
minAttr(A)
For items selected from a relationship, returns the smallest value for attribute A.
Maximum
maxAttr(A)
For items selected from a relationship, returns the largest value for attribute A.
Sum
sumAttr(A)
Returns the sum of attribute A for all items selected from a relationship.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
