Siebel Product Administration Guide > Basic Product Administration > About Managing Product Records > Exporting Product Records for DisplayYou can export product records in several formats for display. For example, you can download files in comma-separated format for display in Microsoft Excel. The supported formats are as follows:
You can request all the rows in the current query or only the highlighted rows. You can request all columns or only the currently visible columns. Currently visible columns are those you have selected for display in the Columns Displayed form. When you export a product with components or bundle for display, only the root-level product record is exported. The structure of the product with components or bundle is not exported. NOTE: This procedure exports only product records for use in other display mediums such as spreadsheets. This procedure does not export the structure of a product or any other information contained in records related to the product record. To export product structures and other information in XML format for use by other applications, see Exporting and Importing Products. To export product records for display
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
