Siebel Product Administration Guide > Products with Attributes > About Managing Attribute Definition Records >
Editing Attribute Definitions
When you edit attribute definitions, you modify the attribute domain. To edit an attribute definition
- Navigate to the Administration - Product screen, and then the Attribute Definitions view.
- In the Attribute Definitions list, select and lock the desired attribute definition.
- In the Versions list, click the Work Space version.
- In the Details view, edit the definitions as necessary.
