Siebel Product Administration Guide > Products with Attributes >
Viewing Product Attributes
If a product has been assigned to a product class, it inherits all the attributes defined on the product class. You can verify that you have defined product classes and associated them with products correctly by viewing the attributes for the products. To view a product's attributes
- Navigate to the Administration - Product screen, and then the Product Definitions view.
- In the Products list, select the desired product.
- In the Versions list, click the name of the desired version.
- Click the Attributes view tab.
