Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility >
Creating Compatibility Matrices
When you create a compatibility matrices, you enter data similar to the data entered in a compatibility rule, but you enter it directly under the matrix record.
You must use compatibility matrices to create compatibility rules where the subject is a product class.
Eligibility and compatibility rules are shown in the Eligibility and Compatibility Matrices view, regardless of how you created them. If you create them in Eligibility and Compatibility Rules view and grouped them under a matrix, they are displayed under this matrix. This procedure describes how to create them directly under the matrix.
To create a compatibility matrix
  1. Navigate to the Administration - Product screen, and then the Eligibility and Compatibility Matrices view.
  2. In the Eligibility and Compatibility Matrices list, add a new record and In the Eligibility and Compatibility Matrices list, add a new record and complete the necessary fields. Some fields are described in the following table.
    Field
    Comments
    Name
    Enter a name for a group.
    Matrix Type
    Select Compatibility Rules.
  3. Click the name of the new record.
    The Compatibility Matrix form and the Compatibility Rules list appear.
  4. Add a new record to the Compatibility Rules list and complete the necessary fields. Some fields are described in the following table.
    Field
    Comments
    Subject Product
    Select the subject product. The default is the product that is selected in the Products list, but you can select any product to replace it.
    NOTE:  Make an entry in only one of the fields Subject Product, Subject Product Line, and Subject Product Class.
    Type
    Select the type of the rule. Options are:
    • Compatibility - Requires. If the subject product is purchased, the object product must be purchased.
    • Compatibility - Excludes. If the subject product is purchased, the object product must not be purchased.
    Object Product
    Select the object product.
    NOTE:  Make an entry in only one of the fields Object Product, Object Product Line, Object Product Class.
    Object Product Line
    Select the object product line.
    Select the object product class.
    Effective Start
    Enter the date when the rule goes into effect.
    Effective End
    Enter the date when the rule is no longer in effect.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
