Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
HasGenerics Method
This method returns generics and children flags for an item. A port has generics if the required cardinality is greater than the current cardinality and no default product is specified.
Input Arguments
  • ObjId. The unique identifier of the complex object root (for example, Quote ID).
  • RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
  • IntObjName. The name of the integration object.
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
  • Port Item Id. The ID for the port item that will have either children or generics.
  • Path. The path to the parent item of interest.
Output Arguments
  • HasGenerics. Y is present if it does, not present if it does not.
  • HasChildren. Y is present if it does, not present if it does not.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
