Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values >
SetFieldValue Method
This method updates the value of a field in a line item. Input Arguments
- Path. The Integration Id of the line item (or of the parent line item in the case of an attribute).
- FieldName. The field name. This should not be a field that is used and controlled by the Siebel Configurator (such as: Quantity, Port Item Id, Integration Id, Attribute Value, and so on).
- XA Id. (Optional) The attribute Id. Specify only if you are setting the value in an attribute field.
- Value. The value of the field.
- ObjId. A unique identifier of the complex object header (for example, quote ID).
- RootId. A unique identifier of the complex object root (for example, quote line item row ID).
Output Arguments
None.
