Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Select the Siebel Configurator User Interface > SelectCfgUIService MethodSyntaxSelectCfgUIService (inputArgs as Property Set, outputArgs as Property Set) Input Arguments
Output Arguments
UsageFor any method you call on the UI service, you can call SelectCfgUIService to determine which UI Service to load. You must specify the name of your business service in the User Property of the UI Service (Cfg Web UI Service (JS) and Cfg Web UI Service) as follows: Loader Service Name = <your business service name> You must also modify all the related workflows (such as Validate and Customize) to first call this customized method in your business service. ExampleFor example, you can use the LoadInstance method to call SelectCfgUIService as follows: function LoadInstance (inputArgs, outputArgs) var oService = TheApplication().GetService("Cfg Web UI Service Loader"); var oOutputs = TheApplication().NewPropertySet(); oService.InvokeMethod("SelectCfgUIService", inputArgs, oOutputs); var optionId = oOutputs.GetProperty ("Cfg UI Option Id"); var strSupportJS = oOutputs.GetProperty ("High Interactivity"); SetProperty ("Cfg UI Option Id", optionId); SetProperty ("High Interactivity", strSupportJS); oUIService = TheApplication().GetService ("Cfg Web UI Service (JS)"); oUIService = TheApplication().GetService ("Cfg Web UI Service"); oUIService.InvokeMethod("LoadInstance", inputArgs, outputArgs); |
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
