Siebel Product Administration Guide > Designing Products with Components > About the Siebel Configurator Save ButtonWhen Asset Based Ordering (ABO) is enabled, the Save button is disabled. If the Save button is not needed, because the application is using ABO, you can remove it by configuring the product using Oracle's Siebel Tools. The Save button is similar to the Done button, except that it does not exit from the Siebel Configurator session. In general, after you click the Save button, clicking Cancel does not remove the items from the configured product. |
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
