Siebel Product Administration Guide > Creating Custom Siebel Configurator User Interfaces > Process of Creating a Custom Siebel Configurator User Interface >
Adding a Summary Page to the Siebel Configurator User Interface
You can add a summary page that shows the user how they have configured a product. This page displays the relationships from which the user has made selections along with attribute values. It also displays all the selected products the user has chosen with an editable quantity. If needed, you can make this quantity read-only by customizing the summary tab .swt.
Each relationship is a hyperlink. When the user clicks on the relationship name, the selection page containing that relationship displays, and the user can revise their selections.
Figure 10 shows an example of a summary page. The top portion of the page lists the relationships and the attribute values that have been selected. The bottom portion of the page shows the items that the user has selected from each relationship.
Figure 10. Example of a Summary Page
Click for full size image
This task is a step in Process of Creating a Custom Siebel Configurator User Interface.
To add a summary page
  1. In the User Interface view, create a group, as described in Grouping Items onto Pages of the Siebel Configurator User Interface, and complete the fields with the values described in the following table.
    Group Name
    Enter the name that will be the tab or page title name. For example, enter Summary.
    Group Theme
    Select Summary Group Theme.
    Enter a number to set the sequence of the summary page. To make the summary page the last page in the series, enter a sequence number that is higher than the number of the other groups
  2. Do not add items to the group. The system generates the summary page automatically.
Siebel Product Administration Guide Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices.
