Siebel Product Administration Guide > Managing Products with Components > Using Product Classes as Templates for Products with ComponentsYou can create a product class and use it as a template for building other products with components. Use this feature when you have products with components that include the same group of items. For example, you sell desktop computers. You have seven configurable models that share the same chassis types, keyboards, and mouse. You can create a product class consisting of these three relationships. You would then use the product class as the basis for constructing each model. The following features of the product class are inherited by all class members:
NOTE: To turn off the product class template, perform a similar procedure. In Step 5, remove the product class from the Parent Product Class field. To use a product class as a template for a product with components
Siebel Product Administration Guide | Copyright © 2010, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
