Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating UI Group Names
Use this procedure to translate group names that display in customizable product selection pages. To translate a UI group name
- Navigate to the Administration - Product screen, and then the Product Definitions view.
- In the Products list, select and lock the desired customizable product.
- In the Versions list, click the Work Space version.
- Click the User Interface view tab.
- In the User Interface view, click the Name of the UI group whose name you want to translate to drill down on it.
- From the Group List menu, choose Translate Groups.
The Group Name Translations dialog box appears.
- In the dialog box, add a new record and complete the necessary fields, described in the following table.
Language |
Select a language. |
Name |
Enter the translation of the group name. |
- Repeat Step 7 to create additional translations for this UI group name.
