Siebel Database Upgrade Guide for DB2 UDB for z/OS > Running the Database Configuration Wizard to Perform Upgrade Tasks > Information Required By the Database Configuration WizardEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Use this topic to identify the information you must enter when running the Database Configuration Wizard. Make sure you have prepared your upgrade environment, and have collected and verified this information before running the wizard. The Database Configuration Wizard requests information about the upgrade process you want to perform. It then adds this information to a master upgrade file. The Siebel Upgrade Wizard runs after the Database Configuration Wizard exits. The wizard generates the upgrade SQL files and executes some of the SQL files against the Siebel database. For more information on the Database Configuration Wizard, see About the Database Configuration Wizard. |
Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
