Siebel Database Upgrade Guide for DB2 UDB for z/OS > Running the Database Configuration Wizard to Perform Upgrade Tasks >
Starting the Siebel Upgrade Wizard
Upgrades: All upgrades.
Environments: All environments.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
The Siebel Upgrade Wizard executes the upgrade of the Siebel database. It takes a master configuration file as input. This file contains environment information and a driver file name. The Upgrade Wizard executes the steps in the driver file to perform the upgrade.
As the Upgrade Wizard performs the steps in the driver file, it lists the steps in a state log. The state log is located in \siebsrvr\LOG\process\state where process is the upgrade process, for example upgrep_dev_752 (upgrade from 7.5.2, upgrep process, development environment).
If the Upgrade Wizard encounters an error and exits during an upgrade, you can restart it after correcting the error. The Upgrade Wizard reads the state log and continues the upgrade from the last successfully completed step.
When you run the Database Configuration Wizard under Windows, you are prompted to indicate whether or not you want to start the Upgrade Wizard. When you run the Database Configuration Wizard under UNIX, you must start the Upgrade Wizard manually. For more information on the Siebel Upgrade Wizard, see About the Siebel Upgrade Wizard and Driver Files.
About Starting the Siebel Upgrade Wizard After Errors
If the Siebel Upgrade Wizard stops due to errors, verify that you have met these requirements before restarting the wizard:
  • Carefully review the relevant log files to make sure that your upgrade has completed successfully up to that point.
  • If you are continuing a previous and incomplete schema upgrade, do not change the Log Output Directory that you previously selected.
  • If problems with your environment prevent the upgrade from restarting, you must restore the database from the prior base version (the version from which you are upgrading).
    If you need to restore your database and restart the upgrade, delete or store the upgrade log files. The files are located in the following directory:
    Windows: SIEBEL_ROOT\log\PROCESS\output
    Also delete the state.log file. It is located in the following directory:
    Windows: SIEBEL_ROOT\log\PROCESS\state
Use this procedure to start the Upgrade Wizard. See Restarting the Siebel Upgrade Wizard After Pauses for the procedure to restart the Upgrade Wizard after it has paused and Stopping the Siebel Upgrade Wizard for the procedure to stop the Upgrade Wizard.
To start the Upgrade Wizard
  1. Navigate to the following directory:
    Windows: SIEBEL_ROOT\bin
  2. Enter the following command from the command line:
    • Windows: siebupg /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType.ucf
    • UNIX: srvrupgwiz /m master_UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType.ucf
      UPGRADEOPTION_ENVIRONMENT_VERSION_MasterFileType is the portion of the upgrade configuration file name that lists upgrade process, upgrade environment, the Siebel release from which you are upgrading, and the master file type. The file is located in SIEBEL_ROOT\bin (UNIX: $SIEBEL_ROOT/bin). See About the Database Configuration Wizard for further information.
      NOTE:  Specify either mf_m or mf for the MasterFileType value depending on whether you want to start the manual or automatic portion of an Upgrade Wizard process.
      The following table lists examples of some of the file names for an upgrade from Siebel 7.5.x.
      Upgrade Mode
      File Name
      Development env. upgrep
      Development env. upgphys
      Prepare for Production
      Production env. upgrep and upgphys
  3. To begin the upgrade, click OK (Windows) or click Enter (UNIX).
    The Upgrade Wizard resumes from the point at which it stopped.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
