Siebel Database Upgrade Guide for DB2 UDB for z/OS > Preparing a Development Environment for a Siebel Upgrade >
Preparing EIM Tables for Upgrade
Upgrades: All upgrades.
Environments: Development environment only.
This section describes how to drop EIM tables and prepare S_ASSET_POSTN and S_ETL_TIME_DAY for upgrade.
To drop EIM tables and prepare S_ASSET_POSTN and S_ETL_TIME_DAY for upgrade
  1. Navigate to the SIEBEL_ROOT\dbsrvr\db2390\ (Windows) or $SIEBEL_ROOT/dbsrvr/db2390/(UNIX) directory and open the predevftp.txt file.
  2. Edit the predevftp.txt file using the following information:
    1. Change &IP to the IP address of your DB2 host, for example, ZM01.
    2. Change &Username to the your own user name, for example, sadmin.
    3. Change the constant SIEBELQ1 to your own dataset high-level qualifier (DSNHLQ), for example, sadmin, using a command like Replace All.
      Use the same high-level qualifier for all z/OS upgrade datasets. The DSNHLQ must be 18 characters or less and can have multiple nodes separated by periods. A node must be one to eight characters in length. The DSNHLQ may be the TSO ID.
    4. Change &SiebelRoot to your SIEBEL_ROOT directory, for example, C:\sba80\ (Windows).
  3. After modifying the predevftp.txt file, save it, and then close the file.
  4. Double-click ftppredev.bat (located in SIEBEL_ROOT\dbsrvr\db2390) or if you are using a UNIX operating system, issue the following command: Ftp -i > ftpfile.bat.
    You are prompted to enter the password for the user name that you entered in predevftp.txt to replace &Username.
  5. Enter the password, and then press Enter.
    Files to prepare the development environment for the upgrade are transferred from the midtier to the z/OS host.
  6. After the transfer is successful, log on to the mainframe, and navigate to the DSNHLQ.PREDEV0.JCL file, for example, SIEBELQ1.PREDEV0.JCL.
  7. In the job card set the following parameters:
    CLASS=S
    MSGCLASS=X
    JOBPARAM S=YOUR_HOST_NAME
    If your Host server is QA01, the job card should look like the following:
    //###PREDV JOB ACCNT#,CLASS=S,MSGCLASS=X,MSGLEVEL=(1,1),
    // TIME=1440,REGION=0M,NOTIFY=&SYSUID,LINES=9999
    /*JOBPARM S=QA01
  8. From the command line, execute the following commands:
    • C SIEBELQ1 DSNHLQ all
      Where:
      DSNHLQ is the high level qualifier you specified in Step 2.
    • C <SCHEMA> YOUR_DB2_SCHEMA
      For example,
    C <SCHEMA> DB2QUAL ALL
    • C <DEVHOST> YOUR_HOST_LPAR
      For example,
    C DEVHOST QA01 ALL
    • C <DB2LIB1> YOUR_DB2_LOAD_DSN
      For example,
    C DB2LIB1 DSN710.SDSNLOAD ALL
    • C <DB2LIB2> YOUR_SECOND_DB2_LOAD_DSN
      For example,
    C <DB2LIB2> DSN710.RUNLIB.LOAD ALL
    • C <DB2SYS> YOUR_DB2_SUBSYSTEM
      For example,
    C <DB2SYS> Q10K ALL
  9. After submitting the job, enter cancel on the command line or press PF3 to save changes.
  10. Verify that the job ran successfully:
    1. Verify that the RC=0.
    2. Verify that the following datasets were created.
      NOTE:  If you are upgrading from a FINS 7.0.4 application, you need to use the SIS 7.0.4 library.
      • For upgrades of Siebel Business Applications:
    DSNHLQ.PRE.HOR621.JCLLIB
    DSNHLQ.PRE.HOR704.JCLLIB
    DSNHLQ.PRE.HOR752.JCLLIB
    • For upgrades of Siebel Industry Applications:
    DSNHLQ.PRE.SIA621.JCLLIB
    DSNHLQ.PRE.SIA752.JCLLIB
    DSNHLQ.PRE.SIS63.JCLLIB
    DSNHLQ.PRE.SIS704.JCLLIB
  11. Edit the dataset from the list above that applies to your upgrade path.
    NOTE:  Each library has an @@README member to guide you through what to submit.
  12. Submit the jobs as instructed in the @@README file.
  13. Verify that the job ran successfully, RC=0 or RC=4.
  14. After submitting the job, enter cancel on the command line or press PF3 to save changes.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
