Siebel Database Upgrade Guide for DB2 UDB for z/OS > Preparing a Development Environment for a Siebel Upgrade >
Determining Which Template File Was Used During an Extract or Merge
Upgrades: All upgrades.
Environments: Development environment only.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
This section describes how to determine which template file that was used for an extract/merge when a storage control file is created.
To determine the template file that was used for an extract/merge
  1. Open the dbextract.log file and review the command line that was entered.
  2. Check the value for the /i parameter. You can also check the upgwiz.log file for the strgxtrct.exe command string.
    /i D:\18025\dbsrvr\db2390\storage_p_e.ctl
    2004-01-28 09:10:32D:\18025\siebsrvr\bin\strgxtrct.exe /u QADMIN /p ***** /c Q10K /d yourschema /l D:\18025\siebsrvr\log\dbconfig_extract_merge_mf_lk5\output/dbextract.log /i D:\18025\dbsrvr\db2390\storage_p_e.ctl /o D:\18025\dbsrvr/db2390/SStempstore.txt /v D:\18025\dbsrvr/db2390/override.inp /8 D029 /9 SIEBTS /1 SYSDEFLT /2 SYSDEFLT /3 BP1 /4 BP2 /7 EBCDIC
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
