Siebel Database Upgrade Guide for DB2 UDB for z/OS > Generating the Siebel Upgrade Files >
Preparing and Executing the Non-Additive Schema and JCL Files on the z/OS Host
Upgrades: All upgrades.
Environments: All environments.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
When the Upgrade Wizard stops at Pause # 2, you must transfer the non-additive schema files, Temp table DDL files, and the load and unload files that were generated on the midtier to data sets on the z/OS host. You then prepare the files, and apply them to the staging database. Perform the following tasks:
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
