Siebel Database Upgrade Guide for DB2 UDB for z/OS > Generating the Siebel Upgrade Files > Processing the Index Schema File >
Transferring the SCINDX.SQL File to the z/OS Host
Use the following procedure to transfer the SCINDX.SQL file generated by the Upgrade Wizard on the midtier up to Pause #3 to the z/OS host.
NOTE:  Edit the generated files as required by Siebel Technical Notes, Siebel Alerts and Siebel Release Notes on My Oracle Support, or other publications before transferring them to the z/OS host.
To transfer the file generated on the midtier
  1. Navigate to the \DB2390\dbsrvr\dboutput\upgrade directory (Windows) or the /DB2390/dbsrvr/dboutput/upgrade directory (UNIX) and double-click the ftp_pause3.bat file (Windows) or issue the following command (UNIX):
    Ftp - i > ftp_pause3.bat
  2. Enter your TSO ID and password and press Enter.
    The SCINDX.SQL file is transferred from the midtier to the z/OS host.
  3. Review the ftp_pause3.log file which is created in the upgrade directory and verify that the SCINDX file transferred successfully to z/OS staging datasets.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
