Siebel Database Upgrade Guide for DB2 UDB for z/OS > Generating the Siebel Upgrade Files > Preparing the Additive Schema and JCL Files on the z/OS HostEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. When you restart the Upgrade Wizard after creating the staging database, it generates SQL and JCL templates for the file generation process. Specifically, the following files are generated: When the Upgrade Wizard stops at Pause # 1, you must transfer these files to datasets on the z/OS host. These datasets are then used to create the SQL and JCL templates used to perform the upgrade. These tasks are described in this topic. |
Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
