Siebel Database Upgrade Guide for DB2 UDB for z/OS > How the Siebel Database Upgrade Works > About the Siebel Database Configuration UtilitiesEnvironments: All environments. The executables for doing an upgrade reside on the Siebel Server. You can use any upgraded Siebel Server to perform an upgrade of the Siebel database. The Siebel Database Configuration Utilities are a set of files and scripts that provide inputs to the upgrade executables. For best performance, install the Siebel Database Configuration Utilities files on the Siebel Server that you will use to perform the upgrade. The Siebel Database Configuration Utilities files will be installed at the same directory level as the Siebel Server in a directory called To edit and execute Siebel Database Configuration Utilities procedures and maintenance scripts, you must have READ-WRITE access to the Siebel Server bin directories in |
Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
