Siebel Database Upgrade Guide for DB2 UDB for z/OS > Performing the Siebel Repository Merge > About Backing Up the New Customer Repository or Database SchemaEnvironments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The process of merging repositories to create the final customized repository used in the upgrade is time-intensive and resource-intensive. As a result, a merge might sometimes fail because of environmental factors, for example, space constraints. When this happens, the merge process continues, even if there is a fatal database error, and the errors might not be detected for some time. If the merge fails, you must restore the database environment to its pre-merge state and run the merge again. There are two methods you can use to preserve the pre-merge environment so that you can restart the merge again if you need to. Before beginning the merge you can either:
Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
