Siebel Database Upgrade Guide for DB2 UDB for z/OS > Planning A Siebel Database Upgrade >
About Using the DSNTIAUL Utility
In Siebel 8.0, the DSNTIAUL utility is used to unload data from tables. However, the SELECT statements that Siebel 8.0 uses to specify the selected columns to be unloaded cause DSNTIAUL to issue a warning message and return a non-zero return code for every unload job. This makes the process of determining whether an unload job completed successfully or not more difficult.
To avoid this problem, Siebel 8.0 contains a patch for DSNTIAUL which causes a successful unload job to generate a zero return code by changing the selective SELECT warning message to an informational message. Jobs that generate a zero return code require no further consideration. After you apply the patch to DSNTIAUL, all jobs resulting in non-zero return codes must be reviewed. For further information, see About Applying the DSNTIAUL Patch.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
