Siebel Database Upgrade Guide for DB2 UDB for z/OS > Creating the Siebel Staging Database > Preparing the z/OS Host Upgrade Environment and Creating the Staging Database >
Requirements for Upgrade Procedures on the z/OS Host
The user who performs upgrade procedures on the z/OS host requires the following authorities and access:
  • A thorough understanding of zSeries architecture, JCL, and TSO functions and navigation.
  • A TSO account with the authorization to allocate/create datasets on the z/OS host using the high-level qualifier specified in the FTP script.
  • Access to the DB2 target system.
  • DB2 authorities to create DB2 objects and create DB2 VSAM datasets.
  • Grant and Bind authority.
  • DB2 Workload Manager refresh authority.
The default JOBCLASS=Q. Make sure you use the correct job class in the generated jobcards.
Siebel Database Upgrade Guide for DB2 UDB for z/OS Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices.
