Siebel Database Upgrade Guide for DB2 UDB for z/OS > Tuning the Siebel Production Upgrade Scripts > About Tuning the Upgrade ScriptsEnvironments: Production test environment only. Does not apply to production environment. In Release 8.0, you can tune the SQL upgrade scripts in a production test environment to improve their performance and then re-use these tested scripts in the live production environment. For example, the scripts used to upgrade your Siebel database are generic. They update your Siebel database to support all Siebel applications' functionality. You can reduce downtime by tuning these scripts to optimize performance by eliminating unneeded SQL statements. You can then re-use these revised scripts in your production upgrade. You can tune your production upgrade scripts at any time after upgrading the Siebel database schema in your production test environment. Contacting Oracle's Application Expert ServicesCAUTION: You are required to contact your Oracle sales representative for Oracle Advanced Customer Services to request approval from Oracle's Application Expert Services for any upgrade script tuning that you perform. If you do not, you may invalidate your support agreement. It is recommended (but not required) that you contact Oracle's Application Expert Services for help with the following tasks:
Siebel Database Upgrade Guide for DB2 UDB for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
