Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 > Maintenance Considerations for zSeries > About Tracing the Source of a QueryUsing Session ID, administrators can identify from which terminals queries are generated. The session ID is composed of three parts: host IP in decimal, process ID, and serial number. A session ID might look like this: 172.20.80.25_324_1. Eventually the object manager and DB2 host would share the same string that can be used to identify the current connection. Once the session ID is displayed at the Server Manager, you can also check it on the database side. To verify session ID on DB2 host
The session ID string is displayed in the application name field. In case there are many active threads shown here, you should be able to find out your thread by matching the corresponding host name and userid. The session ID is composed of |
Implementing Siebel eBusiness Applications on DB2 UDB for z/OS and OS/390 |
