Product Administration Guide > Product Attributes > Creating a List of Values (LOV) for a Product AttributeWhen you define an attribute that has a list of values domain, you must specify a list of values name. This LOV contains the attribute values. Creating a list of values has two steps: NOTE: The steps for creating a list of values for a dynamic attribute are different from creating LOVs for other uses. Do not define LOVs for dynamic attributes in the Application Administration > List of Values view. This view does not display LOVs defined for use with dynamic attributes. When you define an LOV for a dynamic attribute, you do not have to stop and restart the server for the LOV to take effect. Creating a List of Values NameYou create an LOV name by creating a new record in the dialog box where you select an LOV when defining an attribute. After creating a list of values name, you define the attribute values that make up the list. To create a list of values name
Defining the Attribute Values in a List of ValuesAfter you define the LOV name, you create the values in the list, by creating a record for each attribute value. To define the attribute values in the list
Product Administration Guide |
