Product Administration Guide > Product Attributes > Defining an Attribute with a Range of Values DomainYou define a range of values domain attribute by entering an expression in the Validation field. This expression is used to validate the user's input. If the input is within the range (the expression returns a true), the input is accepted. If the input is outside the range (the expression returns a false), the input is rejected and the user receives an error message. You cannot do attribute-based pricing with the range of values domain type. Attribute-based pricing requires the list of values domain type. The LOV Type and Validation fields determine the attribute domain:
Product Administration Guide |
