Product Administration Guide > Cache Management >
Setting Up Snapshot Mode on the Client
The Snapshot Mode cache for the Siebel Dedicated Web Client and the Mobile Web Client resides on the local machine. You enable Snapshot Mode on the local machine by adding parameters to the application configuration file.
To set up Snapshot Mode on the local machine
  1. Use a text editor to open the .cfg file for the application you are running, for example siebel.cfg.
    This file is located in the bin subdirectory of the Siebel installation.
  2. Add the following entries to the end of the file. If your customizable products are large, consider making the value of eProdCfgNumOfCachedObjects larger than 1000:
    [InfraObjMgr]
    eProdCfgSnapshotFlg = TRUE
    eProdCfgNumOfCachedObjects = 1000
  3. Save the file.
  4. Exit the application and restart.
