Product Administration Guide > Product Classes >
Defining a Class
When you define a class, it is added to the list of all available classes. The name you choose must be unique. To create a subclass, specify a parent class in the definition.
To define a class
  1. Navigate to Application Administration > Class Administration.
  2. In Classes, add a new record.
  3. Fill out the fields in the record and save the record.
    To create a subclass, select a parent class in the Parent Class field.
    The new class definition appears in the Classes list. It also appears in the Class Explorer view.
