Product Administration Guide > Release and Manage Customizable Products > Controlling How Customizable Products are ForecastWhen you add a component to a customizable product in the Product Designer, a check mark displays in the Forecastable field. This means the component is added to product forecasts when the customizable product is included in a quote and the user updates the related opportunity. To prevent components from being added to product forecasts, remove the check mark from the component's Forecastable field in the Product Designer. A Forecastable check box is also available in Quotes >Line Items. This allows you to add or remove a product or component from product forecasts within individual quotes. |
Product Administration Guide |
