Product Administration Guide > Multilingual Data >
Translating the Product Description
Use this procedure to translate the product description.
To translate the product description
  1. Navigate to Product Administration.
  2. Select a product whose description you want to translate.
  3. From the More Info Show menu, choose Translations.
    The languages list appears. If you have not selected any languages, the list is empty.
  4. Add a new record.
  5. Click in the new record's Code field and select a language code from the Language Name dialog box.
    The record is updated with the language name and language code.
  6. Enter the translation of the description in the Description field, and then click Save.
    A new record, containing the translation appears in the languages list.
