Product Administration Guide > Customizable Product Resources > Deleting a ResourceYou delete a resource by deleting the resource record from the Resource Designer. Deleting a resource from a customizable product deletes it from the Pick Resource dialog box. You must select and lock a customizable product before deleting a resource.
Product Administration Guide |
