Product Administration Guide > Customizable Product Rule Designer > Obtaining a Rule Summary ReportYou can obtain a report that lists all the configuration rules in a customizable product. For each customizable product, the report shows the following information: The Rule Summary displays in the Siebel Report Viewer. You can print the report or create an email attachment. This report must be enabled on the report server before performing the following procedure. TIP: The on-screen display of the report typically lists more products on each page than the Products list. Use the report to scan quickly through the product table. To obtain a rule summary report
Product Administration Guide |
