Product Administration Guide > Smart Part Numbers > Viewing a Product's Smart Part Number in a QuoteThe part number displayed in the Part # field throughout the application and in quotes, orders, and so on is the internally assigned part number. This part number is different than the smart part number, which displays in a separate field. Before viewing a product's smart part number in a quote, you must assign a part number generation method to the product. See Assigning a Generation Method to a Product. Assigning a generation method to a product does not cause a smart number to be generated in existing quotes containing the product. |
Product Administration Guide |
