Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Configuration Rule Assembly Language >
Managing Rules Written in Rule Assembly Language
Use the same procedures for copying, editing, and deleting rules written in Rule Assembly Language that you use for rules written using rule templates.
You can modify the Rule Designer list to display the RAL version of each rule you create using rule templates. This is a useful way to learn RAL and to understand more fully how rule templates work. To modify the Rules Designer list, see Displaying RAL in the Rule Designer.
Product Administration Guide Published: 23 June 2003 |
